Solidworks Macro
Hi every one,
I would like to run a Solidworks Macro from LabVIEW,
does any body try this issue before?
could you please give me a tip about how to do it?
Thank you in advance
AJJ
(2,819 Views)
Well it strikes me that the first thing you'll need is a way to talk to SolidWorks. Does it have an activex interface? Can you specify a macro file on the command line when you launch it. I have worked with SW a bit but never macros.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,813 Views)
Mike,
Thank for your response, I have a visual basic code which runs the SolidWorks maco, my new concern is how to translate the VB code to a LabVIEW code.
attached is the VB code in a .txt format, a zipped solidworks macro in a .swp format ,  and Visual Basic image with the macro loaded. May be you can help me.
Thanks in advance
A Jiménez
(2,794 Views)
