Solar cell data fitting
I am trying to use labview for non-linear data fitting of current-potential curves from a solar cell.
The equation I need to use comes from the one diode equivalent circuit of solar cells, that is:
I = Iph - Is*exp(q(Vo-Rs*I)/nkt-1) - (Vo-Rs*I)/Rp
To make it look more friendly, it is of the form:
y = A - B*exp(C*(x-Rs*y)-1) - (x-Rs*y)/Rp
I want to extract Rs and Rp, which are the series and parallel resistance of the cell.
Problem is that it is not an easily solved equation, and a simple least squares fitting method will not work.
Are there any VIs in Labview that could heplp me for fiting my data with this equation?
Aurelien
(3,492 Views)
Do you have any sample data that could be plotted to try and get a curve fit or maybe some values that can be plugged into the equation???  Jsut makes it easier to evaluate and try to get a curve fit.
If you dont want to post your data, there are numerous VIs in the Analyze>Mathmatics>Curve Fitting section on the functions pallette that you can try to play around with.  They are very useful.
Kenny
Kenny
(3,469 Views)
Hi Aurelien,
I designed a software that controls a solar cell tet bed and derieves all the parameters from VI , P V curves of teh tested solar cell
Right now I do not recall what equation/parameters did i use to derieve the Rs and Rp, but i remeber using a simplified equation.
Just hold on till i search for those equations and get back to you
Regards
Dev
(3,467 Views)
maybe try the Nonlinear Lev-Mar Fit (Not in Base Package) located @ mathematics, curve fitting
Greetings from Germany
Henrik
LV since v3.1
(3,462 Views)
hey Solar dude ,
How the progression on your problem ?
I am doin something similar as well.
Maybe you could help me with mine ...
Or show me what you have done so far
(3,391 Views)
