Software or Hardware troubleshooting?
I'm using an NI cDAQ-9172 chassis with LabVIEW 2016. I have been using a VI to test a product for over a year now, totaling several dozen successful tests. Each test runs for 3 seconds. I have one while loop which has four channels using NI 9482 which starts/ends the test of the system by opening/closing valves. This loop is stopped after three seconds using Elapsed Time. A notifier is used to stop the second while loop, which contains a DAQ assistant with eight channels. I acquire data at a rate of 1000 Hz using an NI 9211 and three NI 9215. On my last three tests, the data acquisition stopped for 1-2.5 seconds (never for a consistent amount of time, or at a the same time) while the system we are testing ran properly (that is, the valves opened/shut appropriately). The timestamp on the output file shows gaps in the data; for example, I have data for time 0.000 s - 0.700 s, and the next data point is at 1.700 s. If I run the program without anything flowing through the valves, the data acquisition works as normal. Where should I begin troubleshooting? Is it more likely a hardware or software problem? I cannot attach a VI as it is proprietary. Thanks.
(2,440 Views)
So, the question is what has changed from when it worked properly to when it stopped working properly?
If you didn't change anything in the code, then I would start suspecting hardware.
Why would anything flowing through the valves change the behavior?  What is flowing?
What if you developed a simpler version of your VI that allows you to just cycle the relays and valves and see if they meet the timing requirements called out by your simpler VI.
(2,409 Views)
I have received a lead that suggests hardware and I'm working on troubleshooting that now. Hopefully it solves the problem!
Thanks for the response, I wish I could have deleted the post before you took the time.
(2,406 Views)
