Software Development Management- How?
Hi There,
Does anyone know of a good way to manage software development (in
Labview)?
I've been the only programmer in Labview at my company, so tracking
software changes wasn't too bad. We recently hired a couple of
engineers who also program Labview. Now we're at a point where there
are many versions of the same software springing up. No one here has
any knowledge of software management tools available (except a
spreadsheet program, and a magnetic marker board).
Any links or suggestions are welcomed.
Kind Regards,
-Dorian
dorianjps_at_hotmail.com (change _at_ to @ if e-mailing me)
(3,397 Views)
Dorian,
Having worked in several multi-developer LabVIEW situations, I HIGHLY recommend Perforce.
Perforce is a revision control system application that costs $600 per user. You'll need some space on a central server to store all the depot VIs and other files. LabVIEW 6.1 PDS supports the interface to Perforce directly so you can check-in and check-out VIs as you edit them.
Check it out at www.perforce.com.
BTW - last I heard, NI uses Perforce for its own VIs and even for LabVIEW itself.
Cheers,
Daniel L. Press
PrimeTest Corp.
www.primetest.com
(3,397 Views)
Have you tried to use Source Code Control tool included into Labview. It does exactly what would you like to do - controls source code, keeps history, automates version numbering, etc. It is alredy there in Labview and, depending on your Labview license, is free.
Good luck.
(3,397 Views)
Dorian Grey wrote:
> Hi There,
> Labview)?
A critical part of any source code management is the human level:
deciding which developer will touch what VIs! Then you choose a tool.
We use MS Visual SourceSafe and it works OK for 2 developers.
I've used it on my own for 3 years.
Availabl
e standalone or as part of Visual Studio.
I also know people at a systems integrator (NI Alliance member) who use
it. They still use it for control of up to 20 developers' work.
See its home page http://msdn.microsoft.com/ssafe/ and the best
practices page
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dnvss/html/vssbest.asp
Best, Mark
(3,397 Views)
