Softmotion Axis looses communication when cRIO is restarted
         We are facing a problem with the communication between NI Soft-motion Axis and a cRIO-
Hardware Details:
NI cRIO 9049- Runs on Linux
NI -Soft-motion- 9516
AKD Servo Drive P003 connected to  C series 9516
Software Versions Installed:
LabVIEW 2017
NI Soft-motion 17.0.1
Application Background:
I'm controlling a Servo motor connected to the cRIO via LabVIEW. There's also an FPGA card in the cRIO because there are some c series cards running on FPGA.
1. I have already made sure every time i run the application, i reinitialize the hardware(vi with FPGA included) using the reinitialize example in Soft motion in LabVIEW examples.
2. I make sure when i add the Axis, the cRIO is in Configuration mode.
3. I start the FPGA application first in Configuration mode, and then change it to Active mode before starting my soft motion functionality.
Issue:
Every time i restart/power cycle the cRIO, the Axis looses communication with the cRIO i.e.
1. From the LabVIEW project, when i try deploying the soft-motion axis; it throws an error. Somehow if i manage to get past this, and launch the Interactive Test panel, there's a error thrown (77055).
2. Only way this works again is if i do the below steps
    .In config mode - remove the axis from project,Check and undeploy missing items- Real time scan resource,add           axis and set properties,Deploy Axis and then Start the FPGA vi
     Change to active mode and then start the Interactive test panel
3. This is a problem because even if i remove the connection for a bit and connect the card again on the cRIO; the communication is lost and i have do step 2 again. Apparently this is the only way i can get it run again.
There needs to be a way to reset and connect seamlessly every time i power cycle. Could someone help me with this as its very critical and lot of time goes in fixing this.
Regards
Jay
(2,717 Views)
Did you look at this Knowledge Base Correcting SoftMotion Scan Engine Errors -2147138411 and -77055 ?
(2,682 Views)
    Yes i'm already using that vi (reinitialize project from examples ) as i mentioned in the post.
Regards
Jay
(2,680 Views)
