Snippet on Linux
When I try to drag a snippet from the File Manager to a LabVIEW BD, the *.png appears on my desktop, but not on the Block Diagram. I can generate snippets, but cannot figure out how to use them.  I've tried this with snippets that I've generated, and ones that I've acquired on the web.  Anyone had/resolved this problem?
 - LabVIEW 2020
 - openSUSE 15.1
Greg
Greg R.
(2,068 Views)
Can confirm snippets can't be dragged and dropped onto the block diagram in LabVIEW 2020 for Linux. Tested on OpenSUSE 15.1 and CentOS 8. The snippets being generated under LabVIEW for Linux look correct, and can be copied to a Windows machine where they can be dragged onto the BD and successfully opened.
Attempting to drag a file onto a path constant doesn't work either (it should change to the path of the file), so it's likely a drag n drop issue with LabVIEW and the Linux file manager / window manager.
(2,022 Views)
same conduct with labview 2021 community in kubuntu lts 20.04
(1,998 Views)
Hello guys,
I'm sorry to ride this dead horse here.
Are you aware of anything that has happened in that regard?
I am running LV 2020 and OpenSuse 15.2.
he snippets also only end up on the desktop and not in the block diagram.
Especially under Linux the snippets would save me a lot of work within the Actor Framework.
(1,899 Views)
