Small windows problem
I have without problems used both LV 7 and LV 6.1 on
my computer some month now. But now suddenly all windows
under 6.1 has decided they want to display themselves
as the same-size to small window. All user-interface
windows and all my VIs all come up in a to small window,
all the same size. What on earth can this be ?
I have tried to reinstall LV 6.1, but without any
improvements of the situation. Any good tips about what
could cause this problem ?
Martin
Message 1 of 8
(3,952 Views)
1... Quit both LabVIEWs
2... Find the file "LabVIEW.INI" somewhere in the 6.1 folder and move it to the desktop. (Remember where it was)
3... Start LabVIEW 6.1 - see if the problem is still there.
4... If it IS, then never mind - I'm barking up the wrong tree.
5... If it's NOT, then something got gorched in the file. I don't think a re-install will overwrite that file. You can move the INI file back to where it was and try to figure out what it is, or just trash the INI file on the desktop and re-enter whatever preferences you had set.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 2 of 8
(3,952 Views)
Sorry, CoastalMaineBird, that was not it. Any other ...?
MaP
Message 3 of 8
(3,952 Views)
Can you tell me what size windows open up to? 100x100? 200x200?
If you open up a VI from VI.lib, does it have a small window too?
If you open up a diagram, does it have a small window too?
Do these VIs open normally in LV 7?
Steve Bird
Culverson.com
LinkedIn
Message 4 of 8
(3,952 Views)
What OS are you running on? I remember seeing something on the forum like this recently on a UNIX machine, but don't remember seeing a resolution to it.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 5 of 8
(3,952 Views)
This is getting weirder.
The window size is about 407 x 131.
But, there seem to be a connection with LV 7 !
If I have LV7 open when I start LV 6.1 or 5.1.1,
they come up with all windows the same size as the
first blank VI-size that LV 7 used.
I'm talking about front panels, diagrams, and
all other user windows accessible from the LV menu (Hierarchy window,
Options, VI Library manager etc etc).
Everything is normal under LV 7. I'm using XP as OS.
Martin
Message 6 of 8
(3,952 Views)
I just tried it (Win2000) and do not have that issue.
I left LV 7 open, then opened a few VIs with 6.1 - they came up normally - all windows were their expected size, diagrams were normal.
I would collect all the measurements you can (window sizes, etc.) and contact tech support:
http://sine.ni.com/apps/we/niae_asc.main
Steve Bird
Culverson.com
LinkedIn
Message 7 of 8
(3,952 Views)
I reinstalled the driver to my Matrix Millenium G450 Dualhead,
and that did the trick.
MaP
"CoastalMaineBird" wrote in message
news:506500000005000000501B0100-1042324653000@exchange.ni.com...
Message 8 of 8
(3,952 Views)
