Small Problem with Simple Labview Code. Please Help :(
Can you upload the VI in 2011
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 11 of 22
(1,690 Views)
Hi Zoneator,
You currently have the maximum queue size set to one and an infinite timeout on your enqueue element.  Once you enqueue the first element, your loop waits indefinitely for the one spot to become available. Due to dataflow dependencies (you shouldn't be wiring that stop button through to the parallel loop), your bottom while loop cannot execute until the first has finished and exited. You'll need to use a different mechanism (such as a local variable or a separate control) to stop your second loop.
Tom L.
Message 12 of 22
(1,689 Views)
How do i do that? Sorry this is my first time.
Message 13 of 22
(1,688 Views)
First i can't see any reson why upper while loop will execute only 2 times.
Second you need to learn dataflow ( you can not stop lower while loop with stop button wired like that )
third if you are not using event structure you are not doing your assignment correctly.
fourth read about every function from LabVIEW help before using it and see some example also.
Many more............
But most important is don't expect any code from as because it is your assignment.
 Edit..
May be i saw it too quickly yes your bottom loop will not start executing until upper stops.
and you queue size is one so without dequeue it will stuck.
Message 14 of 22
(1,687 Views)
I've got it to work! Thank you so much tom. This is my solution. Tom and Ranjeet, do you guys think there is a way to incorporate an event structure into this?
Message 15 of 22
(1,676 Views)
Hi neos,
I found out the mistake. The wiring of the stops was a very amateur mistake (I don't know why i did that :/) I wasn't expecting any actual labview code, just verbal directions. My college research project involves labview and a ton of queueing (this assignment was just a verbal assignment from my grad student). I'm having a difficult time incorporating event structure for this. I don't see how to incorporate the value signaling property node into the event. Thanks
Message 16 of 22
(1,669 Views)
Yes better use event structure because in your case you gonna need to interact with user.
--Ranjeet
Message 17 of 22
(1,668 Views)
Ranjeet,
It doesn't need any user interaction. The event structure just needs to be triggered by a value change from the random number generator, so it can do its function which should be to multiply the random number by 3. I think this is supposed to be the purpose.
Message 18 of 22
(1,664 Views)
As you said multiplier can be changed
--Ranjeet
Message 19 of 22
(1,661 Views)
Zoneator,
Now it is the time to learn the link Tom has given about Producer Consumer.
Make some actions like Start, Stop, Pause in producer loop with event structure and in consumer use a state machine.
Read it and give a try.
You can use user events.
Message 20 of 22
(1,659 Views)
