Slow speed code in formula node
Attached the .vi. It works correctly, I have verified and it is what I was searching for. No need others.
Thank you very much for supporting me.
Mal
Message 11 of 19
(1,554 Views)
Accepted by topic author Mal123
A few simple suggestions:
  • Use complex math to do the input processing.
  • x2 and /2 should be done using scale by powers of two because it is especially easy in binary.
  • I am not sure if the compound multiply really constant folds the (0.0005x pi x pi), so I would take that out.
  • I would recommend to save the VI so the controls are in view.
  • it is useful if the controls have some default values.
Message 12 of 19
(1,530 Views)
Another level of a smart mind.
Thanks Altenbach!
Message 13 of 19
(1,506 Views)
I would like to convert attached Open Office BASIC code to LabVIEW, it is related to inductance of a solenoid.
Is it possible then to adapt it for more layers?
A section of it was already done by Bob_Schor and Altenbach.
Message 14 of 19
(1,143 Views)
The easiest way is probably to convert the given BASIC code to C using any available AI assistant (I'm serious), then wrap it in a DLL and use it in LabVIEW. I don't think there will be significant performance improvement (DLL could be a bit slower in this case), but at least it will save you time wiring such code.
This is what I've got from Microsoft Copilot:
Spoiler
double Mut(double r1, double r2, double x) {
	double a = sqrt(pow(r1 + r2, 2) + pow(x, 2));
	double b = sqrt(pow(r1 - r2, 2) + pow(x, 2));
	double c = a - b;
	double ci = 1;
	double cs = c * c;
	double ao, co;
	do {
		ao = (a + b) / 2;
		b = sqrt(a * b);
		a = ao;
		co = c;
		c = a - b;
		ci *= 2;
		cs += ci * c * c;
	} while (c < co);
	return 0.0005 * pow(M_PI, 2) * cs / a;
double LayeredCoil(double d, double r0, double kx, double ky,
				   int n1, int n2, int n3, int n4, int n5, int n6, int n7, int n8, int n9, int n10)
	int Nturns[10] = {n1, n2, n3, n4, n5, n6, n7, n8, n9, n10};
	double xoffset[10] = {0}, yoffset[10] = {0};
	int MaxN = Nturns[0];
	int N = 0;
	double g = exp(-0.25) * d / 2;
	double L = 0;
	double M = 0;
	int i, j, iLayer, jLayer;
	double ix, iy, jx, jy;
	// Find the layer with the maximum number of turns
	for (i = 1; i < 10; i++) {
		if (MaxN < Nturns[i]) {
			MaxN = Nturns[i];
	// Calculate the x and y offsets for each layer, total turns, and self-inductance
	for (i = 0; i < 10; i++) {
		N += Nturns[i];
		xoffset[i] = (MaxN - Nturns[i]) / 2.0 * kx;
		yoffset[i] = r0 + ky * i;
		L += Nturns[i] * Mut(yoffset[i], yoffset[i], g);
	// Change Nturns array to running total of turns
		Nturns[i] += Nturns[i - 1];
	// Calculate mutual inductance for every pair of turns i and j
	iLayer = 0;
	ix = xoffset[iLayer];
	iy = yoffset[iLayer];
	for (i = 0; i < N - 1; i++) {
		if (Nturns[iLayer] <= i) {
			iLayer++;
		jLayer = iLayer;
		jx = ix + kx;
		jy = yoffset[jLayer];
		for (j = i + 1; j < N; j++) {
			if (Nturns[jLayer] <= j) {
				jLayer++;
				jx = xoffset[jLayer];
			M += Mut(iy, jy, ix - jx);
			jx += kx;
		ix += kx;
	return L + 2 * M;
No idea if the result is correct or not (but at least Mut seems to be not so bad).
Attached code (LabVIEW 2018 + NI CVI 2020).
Message 15 of 19
(1,127 Views)
Hi Andrey Dmitriev,
You have been very fast!
Thank you, but I cannot use dll, I need LabVIEW code, or at least a formula node...
...is it possible to put your code in a formula node?
Message 16 of 19
(1,117 Views)
@Mal123 wrote:
Hi Andrey Dmitriev,
Yes, of course, you can use provided C code as "getting started" for Formula Node (and then you will get your performance penalties back), or accurately rewrite everything in pure LabVIEW (there are trivial operations), but here you will need to invest some time for development.
Message 17 of 19
(1,111 Views)
Thank you, my problem is not the time, but my competences, I don't know how to do it.
Mal
Message 18 of 19
(1,107 Views)
So here are two questions:
  • Why are you so instant on using LabVIEW?  You don't seem to know it, you don't seem interested in learning it, even though two "pretty good LabVIEW developers" you credit with doing some of the "hard parts" for you?
  • Have you tried to hire someone?  There is a LabVIEW Forum called "LabVIEW Developers Seeking Employment" that you might try.
Message 19 of 19
(968 Views)
