Slow imc COM (ActiveX)-libraries inside LabView
Hi
I'm using the imc COM (ActiveX)-libraries inside labview. The key command is the "automation open" block from LabView and selecting the desired ActiveX class.
Here his the definition of one of this function:
Function DChannel.GetDataDoubleStartIndex As Long, Count As Long,
                Data As Double() ) As Long
Copies the specified samples in an array of 8Byte real numbers.
Parameters
StartIndex
Index of the 1st sample to copy. The first sample in a channel has an index of 1.
Count
Number of samples to copy.
Data
Array to receive the values. See remarks section.
Return Value
Number of valid samples in <Data>. May be smaller than <count>, when there are not enough samples in the channel (StartIndex + Count -1 > Length).
The problem and also question is why the parameter Data apears as a variant when I use a invoke node for the above method (should be double()??)
When using large Data arrays the libraries are very slow in comparison with VB6. I tested the same functions in VB6 and LabView. In VB6 the COM libraries are very fast! Does anybody know how to improve performance with COM Variants?
Thank you
(3,157 Views)
I'm not sure you can do anything about the speed as long as you use ActiveX. At least that was the answer I got when I asked a similar question here. It seems that there is a lot of data copying between memory spaces that goes on between ActiveX and LabVIEW and, if there is much data involved, it can take a while. Search these forums for the terms safearray or "safe array" or marshal data and you will find more info on what you are up against.
(3,109 Views)
