Slow Unit Test Framework
Using DVRs as class references is the core of G#, possibly you can use the same idea just to force the objects to stay in memory.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 21 of 29
(2,624 Views)
@tyk007: thanks for the insights! Again, do you know if JKI's test tool can provide coverage statistics? It seems to me not.
@Yamaeda: I'd like to try your proposal but I'm not sure I fully got it. Do you mean augmenting the VI under test with an additional parameter which is a reference (DVR) to the class instance? Can you have a look at the example I attached and be more precise about your proposal?
Peter
Message 22 of 29
(2,608 Views)
I'm failry confident it can't - if you really need this feature then VI Tester is not for you.
Message 23 of 29
(2,598 Views)
Your test project is ofc very fast on my computer so i cant really give any feedback on that, but i have a feeling that it might be an issue of objects loading/unloading fully between each run, in which case it should be improved if you can keep the reference alive. One idea of doing so could be to use a DVR of the object.
/Y
Qestit Systems
Message 24 of 29
(2,586 Views)
@Yamadea: I fail to see how your idea would work. What would force LabVIEW to keep the object in memory after finishing a test case. As you say, the overhead seems to be across test cases. Can you please elaborate on your idea?
@tyk007: thanks!
Peter
Message 25 of 29
(2,567 Views)
@Bokor wrote:
@Yamadea: I fail to see how your idea would work. What would force LabVIEW to keep the object in memory after finishing a test case. (the UTF) As you say, the overhead seems to be across test cases. Can you please elaborate on your idea?
@tyk007: thanks!
Peter
Y/ the UTF leaks memory pretty bad the way it is.  Intentionally trying to hold stuff in memeory that is already there seems to be overkill  (Run a p-node "all vi's in memory" after launching and closing a UT config page or running a UT and closing the results)
"Should be" isn't "Is" -Jay
Message 26 of 29
(2,561 Views)
Maybe that idea doesn't work, but i remember some similar issue with VI server that unloaded everything in between runs, and deselecting automatic cleanup allowed it to stay in memory for faster reruns, maybe that doesn't apply here at all. 🙂
/Y
Qestit Systems
Message 27 of 29
(2,557 Views)
@Yamaeda: I see your point, thanks!
@all: thanks for all inputs!
My conclusion is that no straightforward native solution exists to significantly speed up NI's UTF, at least when used for LVOOP. My frame of reference is 5-6 seconds (with UTF) versus <0.20 seconds (JKI's VI tester as reported by tyk007).
Again, thanks for the discussion.
Peter
Message 28 of 29
(2,543 Views)
FYI: a new tool called InstaCoverage has been introduced via LabVIEW Tools Network with a specific goal to improve on the run-time efficiency of LabVIEW's Unit Test Framework. Unlike other alternatives InstaCoverage supports code coverage and improves on UTF's run-time by up to two orders of magnitude (e.g., 1h vs 30s in an example commercial LabVIEW project). Here's the link: http://sine.ni.com/nips/cds/view/p/lang/hu/nid/216652
Message 29 of 29
(2,415 Views)
