Slow Sample Rate using NI cDAQ 9172 Chassis
I am having an issue where I can not get faster than 2 Hz (two samples per second) out of my NI cDAQ 9172 Chassis.
I am running an analog input task, configured in MAX.  When I start my test, I then commit the task, and then progmatically start and stop the task, so there should be very little overhead since the task has already been commited before starting.
I am reading in 8 thermocouples and one 4-20mA sensor (in the same task), which covers 3 modules (2 thermocouple, one 4-20mA).
I have tried removing the current measurement, which gave me a slight increase in performance (3 Hz).
The cDAQ can supposedly clock up to 1Mhz, I am only looking for 100 Hz or so.
I am connected via USB to the computer, and it is a 2.0 connection.
I am saving to disk via TDMS, but there was no change in sample rate even when I disabled my tdms logging.
When I disble the task, and let me loop just run, it will do as fast as the processor (Intel Core 2 duo with 3 gb of ram) can go, so I have narrowed it down to the task itself.
Am I missing a setting?
Kenny
(2,289 Views)
Ok, so I dug more into the NI 9211 Thermocouple module specifications, and they state:
Conversion time................................70 ms per channel;
420 ms total for all channels
including the autozero and
cold-junction channels
So I guess I am stuck with my sample rate, unless I want to upgrade to a different module
Kenny
(2,285 Views)
