Slider text labels and markers
Hi All,
I'm a newbie at this Labview business, so hopefully the problem I'm
having is purely due to my newbie-nature...!
I've been making a slider where I have a series of labels to be placed
at some marker positions. So, I have a property node for the slider to
which I pass an array of marker positions (e.g., 0, .25, .5, .75, 1)
and marker labels (e.g., MIN, SOME, MID, LOTS, LOADS) at runtime.
However, the ouput is odd - markers appear at the correct positions,
but the text is incorrect.
E.g. 1: If I have Markers (0, .5, 1) and Text (MIN, MID, MAX), the
slider is labelled (0 - MIN, .5 - MAX, 1 - MAX).
E.g. 2: If I have Markers (0, .25, .5, .75, 1) and Text (MIN, SOME,
MID, LOTS, LOADS), the slider is labelled (MIN, MID, LOTS, LOADS,
LO
ADS).
So, the second text label is ignored and the others sort of 'shifted
left', with the final label being duplicated at the last marker
position.
Any ideas?
(BTW - LV 6i, Windows XP)
Steve.
Message 1 of 9
(6,897 Views)
Steve,
Please find the attached example that has 5 markers. You can change the marker labels in the array.
The VI was created in 6.1 and I saved it back to 6.0, but did not test it in 6.0. It should work the same.
Zvezdana S.
Message 2 of 9
(6,897 Views)
I am using 8.5.1 and I have experienced the same problem, five years later! The workaround provided will work for sequential values of text labels only - I am programmatically assigning Marker Values for non-equally spaced ticks.
For instance, when Marker Values are programmatically set to (1, 2, 4, 😎 and the Text Labels are programmatically set to (one, two, four, eight), the text labels actually put onto the slide are (one, four, eight, eight). Now here's the kicker: when I set the Text Labels to (one, DUMMY, two, four, eight), they show up properly on the slide.
As Steve orignally noted, the second text label is being ignored. Further, the "dont-show then show" trick suggested by Zvezdana as the workaround does not fix this problem. What gives?
Jack
Message 3 of 9
(6,625 Views)
Hi Jack,
I took a look at the functionality of mixing markers and text label and believe what you are seeing is a bug. I will report this to the development team.
Sappster
Message 4 of 9
(6,592 Views)
Thanks, Mark!
Message 5 of 9
(6,587 Views)
This bug still exists in LV2012
_____________
Creator of the BundleMagic plugin for LabVIEW!
Message 6 of 9
(5,986 Views)
This bug still exists in LV2015
Message 7 of 9
(5,689 Views)
Bug still exists in LabView 2016 (16.0)
Message 8 of 9
(5,471 Views)
Message 9 of 9
(5,170 Views)
