Slider not Sliding at run time
What a mystery!  Please let us know if and when you find the solution.  Perhaps try writing a new VI with sliders to see if it has the same problem.  I suspect something got corrupted in your VI.  You can even try copying and pasting sections from your VI to a new VI.  Try the slider after each copy and paste.  You may find a corrupted section that way.
- tbob
Inventor of the WORM Global
Message 11 of 15
(1,129 Views)
Using the magic of Subversion SCC, I reverted until I found a version that works.  The only difference is the inclusion of the legacy VIs for processing keyboard strokes from the user.  It would seem that this is the problem.
I have jettisoned this code for now.
Problem solved, but not understood.  I am sure someone can explain to me why the inclusion of the "Acquire Input Data.vi" should cause this behaviour.
Wes Ramm, Cyth UK
CLD, CPLI
Message 12 of 15
(1,112 Views)
I like this.  You solve your own problem and give yourself the credit.  Smiley Very Happy  Brilliant!!!!!
- tbob
Message 13 of 15
(1,094 Views)
Give credit where credit is due, I say!!  Plus, indicating that the problem is solved lets other's choose to ignore the link.
Wes Ramm, Cyth UK
CLD, CPLI
Message 14 of 15
(1,078 Views)
So, I was wrong.  The keyboard polling was NOT the solution....  Everything was working fine on Friday when I powered off for the day.  this morning, on first start, I am back to the same behavior.
NI has advised that I install SP1.  After 1 download, the SP will not run.  I am downloading again.  Will advise.  In the meantime, still looking for ideas.
Wes
Wes Ramm, Cyth UK
CLD, CPLI
Message 15 of 15
(1,041 Views)
