Slider fill color curious in executable
I use a slider where I change the fill color depending on the state using the property node "Fill color".
I switch between green and yello.
In the executable the color behavior is strange: not the full aerea is changing to the other color (see the small aera in the picture).
Any idea?
Enviroment:
- LabVIEW7.1
- Windows XP
(2,687 Views)
can you let me see the code. i can not tell very much from the picture
(2,624 Views)
Hello
Thanks for your response.
In the meantime I get the information from NI that's a bug in LabVIEW, that appears only in the exe-Version of your application.
(2,607 Views)
