Slider control bug?
When I try to open a custom control I saved I get an error message:
"Unable to display the front panel of the VI. The VI's front panel may have been removed"
Here's what I did:
-Created a new control
-Put a classic simple slide down
-Changed to indicator
-Show digital display
-Right click and select 'replace' on the digital display and replace it with the classsic style simple numeric
-Change the background/foreground colours
-Save the control
I've tried this a few times and get the same result each time. It seems to be replacing the digital display which causes this behaviour. Any ideas?
Steve.
Message 1 of 9
(5,645 Views)
No help, just a confirmation. In 2009 f2. I tried this and upon opening the control, I received...
LabVIEW: Generic error.
An error occurred loading VI 'Control 1.ct;'.
LabVIEW load error code 3: Could not load front panel.
...and it does appear to be the changed digital control which causes the problem.
Richard
Message 2 of 9
(5,637 Views)
Does it remain a control after you change it to an indicator...?
Hummer1
Message 3 of 9
(5,633 Views)
Hummer1
Mine changed to an indicator, at least it made the proper appearance changes from control to indicator.
However... as I was trying a few other things, I placed a modern slide control and began to change the numeric indicator to the classic simple style, and received a fatal error as shown in the attached gif.
Richard
Message 4 of 9
(5,615 Views)
FYI, NI: Upon restarting LabVIEW, it said there was an error with StdNum.cpp line 2418
Richard
Message 5 of 9
(5,594 Views)
In a way I am pleased it wasn't me doing something silly!
I forgot to mention I am running LabVIEW 2009 (9.0f2 32 bit) on 64 bit windows 7.
Has anyone from NI seen this thread?
Steve.
Message 6 of 9
(5,560 Views)
Accepted by topic author St3ve
Hello all,
Thanks for your feedback, I have just been asked to look into this and report back any findings, so let me do some research for any known issues and I'll get back to you.
Kind Regards,
Michael S.
NI UK & Ireland
Message 7 of 9
(5,534 Views)
Hello All,
This has been reported to R&D (CAR 195727) for further investigation.
Jon S.
LabVIEW NXG Product Owner
Message 8 of 9
(5,492 Views)
I just did the exact same thing and got the same result.  Now I cannot even open my vi calling my custom control and have to revert back to a previously saved version losing some work in the process.
steffan
Message 9 of 9
(5,412 Views)
