Slider Control
Is there a way to have a slider control that when you let go of control it goes back to a certain value.  For example I have a two way directional valve where 0 V is reverse and 5 V is closed and 10 V is forward, so when you slide the slider up the valve operates in the forward position and once you let go the slider goes back to 5 V the closed position
thanks for any help
(3,601 Views)
Have you tried a search?
I need to make a snap-slider.
(3,597 Views)
Attached is an example, it uses a local variable to force the slider back to a value of 5 when the user mouses up on the control.  Might be a good starting point for you.
Cheers!
(3,592 Views)
thanks, i appreicate the help
(3,586 Views)
