Slide indicator
I'm trying to use a slide indicator that should work like this: considering a range of 100, if the value is less or equal 20 , for example, the fill color should be green, if the value is between 20 and 40, so, the fill color should be green up to 20 and yellow from 20 to 40 and so on. I tried to use the active slide property but I didin't get the effect I want. Anyone has an idea how to do this?
Thank you in advance!
Message 1 of 10
(6,038 Views)
Hi Luci_UFRJ,
you can use the "FillColor" property to set the color.
Hope it helps.
Mike
Message 2 of 10
(6,036 Views)
But the fill property will change the color of the hole fill and not of segments.
Message 3 of 10
(6,031 Views)
Hi Luci_UFRJ,
yes it´s correct, but you can add additional sliders with different colors.
See the attached example.
Hope it helps.
Mike
Message Edited by MikeS81 on 10-13-2008 08:36 PM
Message 4 of 10
(6,024 Views)
You need to layer sliders on top of each other, like this...
Beat to the punch!
Message Edited by jmcbee on 10-13-2008 12:51 PM
Message 5 of 10
(6,015 Views)
Accepted by topic author Luci_UFRJ
Here is a better version of that VI
Versions 8.6 and 8.0
Message Edited by jmcbee on 10-13-2008 01:33 PM
Message Edited by jmcbee on 10-13-2008 01:37 PM
Message 6 of 10
(5,996 Views)
Thank you, guys!!!! It works!
Message 7 of 10
(5,988 Views)
Here's the same with slightly less code. 🙂
Message Edited by altenbach on 10-13-2008 12:45 PM
Message 8 of 10
(5,983 Views)
And even less code. Ideally, you would wrap all this into an Xcontrol.
Message Edited by altenbach on 10-13-2008 01:07 PM
Message 9 of 10
(5,971 Views)
I like this last solution with the event structure, you should adopt it instead of mine.  There are fewer property nodes, it is more scalable and easier to read.
Message 10 of 10
(5,968 Views)
