Skipping step in Labview Config File
Is there a way skip a step in a Config file with Labview? I'm on a business trip setting up a process line in which labview is used to program and set parameters in a backup tape drive system.
Anyhow, there is one step of the sequence which uses a config file to program the drive. This step needs to be run so I can't skip the step in the Sequence. However, within the config file there are a few steps which sets parameters in the tape drive which I do not want. If I erase these steps, LABVIEW gives an error upon startup. If I erase the parameters values, it is interperted as value zero which is also not wanted. Is there a way to have labview skip setting these parameters or ignore these parameters without having to change th
e source code ? If not, How can I go about changing the source code for this ( granted I'm fairly new to Labview )
Thanks for any help
(2,901 Views)
You have to change your source code. The config functions work like a data repository. They do not know which processing you want to do with the data.
If you want to have a processing depend on the fact that a parameter or section is present or not you need to connect the "found?" output of ReadKey.vi or Get Key Names.vi to a case structure. Use this to skip over steps in our sequence.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,901 Views)
