Skip non-image files when adding images to array from file
I am reading images that are stored in a folder into an image array. I have a slight problem when a non image file (using .png) is present.
What I have tried is to use a case structure to check if the file extension is a png (if it is a png then add to the array), if it is not a png file, then the false case is executed and a blank is inserted into the image array, since I have selected to "Use default if unwired". What I ultimately would like is for it to skip all non image files and have a image array with no blanks.
I honestly do not know what to do.
Could anyone please offer advice? Let me know if you would like any other information.
Richard
(2,748 Views)
Accepted by topic author tyrrellvw
List Folder.png Use a Pattern filer when you get your files from the folder, then you don't need to sort the files out after - SimpleSmiley Happy
James
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
(2,727 Views)
Hi Richard,
while James noted the correct approach to only list PNG files in the first place you should consider for the next time:
Only do your "add to array" operation in the TRUE case. Then you don't need to output some default values from your case structure!
(2,724 Views)
Thank you James!
I will be honest, I saw that VI but I was unsure about what it did. I was using the List Folder VI and then comparing each file in the folder.
Still a rookie and had to self teach myself LabVIEW, there are a few things that I overlook.
Richard
(2,721 Views)
