Single precision numeric control
Hi
I need to make a numeric control in the range 0.1 and 0.9 with 0.1
increments. I've used a single precision number, and have set up the data
range, increments and decimal place setting as appropriate but at either
extremity the control misbehaves and does not increment properly. I think
I've must have missed something somewhere as I have this working fine for
an integer control (range 1-10, increments of 1).
Can anyone help please?
Many thanks in advance
Cheers
Bill
wsymonds@clara.co.uk
(3,857 Views)
Set maximum to 1 intead of 0.9 and then it works.
"Bill Symonds" wrote in message
news:memo.20000629191218.53151B@wsymonds.clara.net...
> Hi
> Cheers
> Bill
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfee
ds.com - The #1 Newsgroup Service in the World!
-----== Over 80,000 Newsgroups - 16 Different Servers! =-----
(3,857 Views)
Bill Symonds schrieb:
> Hi
> Cheers
> Bill
Only a hint:
don't forget, that with binary representation of floating point numbers it is
not possible to create exact 0.1, 0.2, etc... since all fractional bits are
also a (negative) power of 2. See the atached scre
enshot as a simple
example...
[Image]
Jens-Achim
(3,857 Views)
In article <395CC633.8CB7E5FB@gmx.de>, tgs.kessel@gmx.de (Jens-Achim
Kessel) wrote:
> Only a hint:
> it is
> are
> also a (negative) power of 2. See the atached screenshot as a simple
> example...
> [Image]
> Jens-Achim
Thanks for that and to the other for the tip above. This is the root of
the problem. I've to make a digital control such that it behaves itself at
either extremity for the data range I need to control in. Unfortunately
the choice of representation on the screen seems limited to a simple
numeric control like the one in your picture. If I wanted to do it using a
slider I'd be stuc
k with a slider which either
a) didn't behave properly at the extremes using the increment arrows at
either end
or
b) max and min points on the slider were outside the data range which
could actually be set but could still be visually selected using the drag
slider method.
Regards
Bill
(3,857 Views)
