Single beep when within temperature range
Hello. I have an issue. I have a project where I want a beep when the temperature changes.
I have 3 categories. Hot, warm, and cold. Cold(0-25 degrees), Warm (26- 60 degrees) Hot (61-100 degrees).
Is there any function I can use to get a beep for when the temperature changes from its category?
I know how to get the beep. The problem I'm facing is preventing the beep when it is still within the same category.
(2,369 Views)
Accepted by topic author Rayhl
Sounds like you want a function that checks if a threshold has been crossed. Then set a boolean to true, then check if you need to "beep".
Are getting hung up on the logic? Or just cant find the correct BD functions palette?
(2,365 Views)
Use a feedback node and compare the previous category to the current category and beep if they differ.
(2,346 Views)
Hellooo thanks for both of your replies. I managed to get the simulation to work. I used the (is value changed) pallet to prevent the beep from reoccurring even tho its within the range of the category.
(2,304 Views)
Hi Ray,
do you really need so many comparisons and boolean operations for such a simple task?
(2,281 Views)
