Simultaneously acquire and set one output
Hello, I have an application which I should set one digital output and simultaneously acquire the response from my system using the A/D channel. The problem is: the response is very fast and the acquired signal is nothing, because the signal is already gone. I do not know if there is some parallel process that I can do to solve such issue. Im using the LABview Agilent U2500 Series Pallets. Best regards Ednardo
(2,303 Views)
Could you post your code?
(2,278 Views)
