Simultaneous multi-channel operation
Hello All,
Looking for some guidance here. A simplified summary of the application is the user scans a unit SN (battery equalizer) and the channel on a 10-channel rack. This creates a Test Id and calls the control vi asynchronously (call and forget), there is a separate identical control vi for each channel. Each non-reentrant control vi runs independently and completes 80 minutes of various tests. The subvi's in the control vi that do not use a hardware resource I have made reentrant vi's, the vi's that cannot be reentrant (use a hardware resource - DAQ for measurement or relay switching) I am calling asynchronously (call and forget). There are also some non-reentrant vi's that need to complete before moving to the next step, so I am calling these by reference so I can close the reference after they complete. These are very simple vi's that run very quickly but I think this is where the issue is, these vi's seem to be held too long. Everything works but I am seeing some performance issues because of "subvi waiting to run" but I haven't been able to identify what is holding the vi. I am not against completely refactoring the application. As a last resort I could switch to testing in batch mode to maintain sequential flow, but I would prefer to maintain individual channel control. I am using global variables, but I don't believe this is the cause of any issues. A GV channel status is shown on the front panel (available, testing, pass, fail) and a GV stop flag exists for each channel to stop the control vi if there is a test failure.
(96 Views)
Hi Shawn,
I guess another "control VI" running in parallel is blocking the subVI from running…
Guidance for … what exactly?
It's hard to guide when you don't show any code…
(82 Views)
It was not allowing me to edit the posting, but I attached a control vi here. I still need to do the vi cleanup and documentation, but the test rack functionally works as designed on all channels. It's just the more channels you scan in, the slower things process. This application is intended to run 10 control vi's simultaneously but independently. When I scan in 3 channels the timing is minimally affected but that increases with every channel scanned. For a point of reference, I am controlling about 50 pieces of equipment and using the DAQ to measure voltages and currents through shunts and current sensors and saving all the data to a database. All of my test platforms I have built to date were single channel with sequential flow, so simultaneous multi-channel control new to me. It has been a fun project, but I would like to wrap it up now.
(22 Views)
