Simultaneous 3D graphs
I am looking for a way to update the viewing angle of two or more 3D graphs (3D surface) by simply changing the view of one graph or the other.  These plots cannot be plotted on the same graph.  I would appreciate any help.
Using LabView 8.20 Developer Suite
(2,718 Views)
Here you are. Better done using events, but this is abit trickier since the changing of the viewpoint doesnt generate events on its own.
For case 1 (boolean array to number returns 1 for true/falste, 0 for false/false, 2 for false/true and 3 for true/true) just wire another pair of inputs (refnum and cluster) to the property node. Default does nothing.
Hope that helped!
(2,700 Views)
