Simulink
i found a problem in simulating a power plant when a message lasts apper all over  the time:
""Derivative input 1 of 'model/Transfer Fcn' at time 0.001 is Inf or NaN. Stopping simulation. There may be a singularity in the solution. If not, try reducing the step size (either by reducing the fixed step size or by tightening the error tolerances)""
thanks to every help.
(3,524 Views)
I'm sorry but you posted on the wrong forum. If you have a simulink problem, you should ask the folks at The Math Works. Simulink != LabVIEW and The Math Works != National Instruments.
(3,478 Views)
