Simulink and Simulation Interface Toolkit
I have got LabView 7.1, Matlab 7.0 (R14), Simulink 6.0 (R14) and I work with Windows XP.
I want to read in Labview a DLL created with Simulink and Real Time Workshop.
I read that I have to buy the Simulation Interface Toolkit. Before buying it, I would like to know if I will be able to do so with my old software versions.
And will it work in "realtime" that is to say how long does it take to call the DLL from Labview?
Many Thanks,
Rémy
(3,198 Views)
No answer?
(3,181 Views)
If you will use the LabVIEW Simulation Interface toolkit, you need have :
_ MATLAB® or Simulink® vers. 13.x ou 14.0-14.3
_ Real-Time Workshop® version 13.x ou 14.0-14.3 (The MathWorks, Inc.)
_ Visual C++ 6.0 or Visual C++ .NET 2003 (Microsoft)
_ and LabVIEW vers. 7.1 (or higher)
It's diffictult to give the time caused by LabVIEW for call the DLL, because it's depending of you computer and application.
You can found on the link below a tutorial about how to create the DLL for call him on LV.
http://zone.ni.com/devzone/cda/tut/p/id/3447
Christophe S.
Account Manager East of France І Certified LabVIEW Associate Developer І National Instruments France
(3,167 Views)
Also note that you will need Simulation Interface Toolkit version 3.0 to work with LabVIEW 7.1. SIT 4.0 is only compatible with LabVIEW 8.5. Both these versions will work with your existing versions of third party software.
Jarrod S.
(3,158 Views)
