Simulink, Labview and DLL
Hi all,
I can communicate my model in Simulink with Labview using the SIT and without working in real-time. However,now, although I have made a DLL(Dynamic Library Link) with Simulink and my compiler, I don´t know how I could run it in real-time with my target calling the DLL.
This is, instead of using my model (*.mdl) in Matlab, I want to use the DLL but I don´t know how I must call it from Labview.
If someone could help me, I would be very grateful.
Ziman.
(2,983 Views)
considering that you have recent versions of LabVIEW and SIT, you could do that ( run the model in an RT target ) using the SIT Connection Manager ( Tools - SIT Connection Manager ). In this dialog box, you will have to select Real-Time Target, insert an IP and choose the path to the Model DLL. Once configured, then click on OK button and when running the VI, it will download the model to the RT Target
If you open an example that comes with SIT called Sinewave ( Help - Find Examples ), you will have the information to run it in an RT Target in the front panel. For more information, here you have a link ( http://zone.ni.com/devzone/cda/tut/p/id/3583 ).
I hope this helps
crisR
(2,962 Views)
