Simulation of IQ on LabVIEW FPGA
I am trying to write a logic for generating an simulated IQ signal, I can simulate generation of real and imaginary signal but unlike host VIs, but I haven't been able to find a way in FPGA  to create a complex signal from real and imaginary. I have been through high through complex multiply functions but, it requires 2 complex number for operation. I am looking for a way to convert the sine and cosine signal for complex signal.
How can I implement that in FPGA ?
(802 Views)
Hi Vaibhav,
A complex number simply is a compound of two floats (with some additional conventions about using them).
Have you tried to work with two float values in the FPGA?
(784 Views)
It seems to me you would simply put the in phase (I) signal in the real part of a complex number and the quadrature (Q) in the imaginary part.  An array of these complex values would be the complex waveform.  The "Re/Im to Complex" VI can do this for two arrays.  Another option is to interleave the two arrays to a single array and type cast this array to a complex double array.
(766 Views)
See https://youtu.be/vVjWFFclU6I?si=r01AAep_L9A69EXN&t=94 (roughly at 94 seconds) they show IQ data.  They use a cluster (typedef) with two fixed point values for I and Q.  See if you can find these functions.
How are you going to generate the IQ data on the FPGA?  Maybe Xilinx DDS?
ALE Consultants
(745 Views)
