Simulation and Testing my results
The attached file is supposed to receive 3 signals from the microcontroller via serial communication in the format
sig1sig2sig3
Is there a way I could simulate and test the file without connecting it to the hardware???
(2,832 Views)
Easy. Take out the VISA Configure and VISA Read VIs and the things conected to them. Change Read Buffer indicator to a control and type in test data.
Alternatively, if there is a lot of data that you do not want to re-type, put a Read Characters from File VI in place of teh VISA Read and get your test data from a text file.
Lynn
(2,832 Views)
Or, write a VI that outputs to com2 and wire com2 to com1 with a loopback cable.
(2,832 Views)
Hey Lynn
Thanks for your response.
I did understand what you are trying to say but that only enables me to do the test once
If you notice my file, I have to read the following format in a while loop
sig1sig2sig3
I am trying to find a way whereby i can simulate multiple reads.
Also, I want to channel all the incoming data via "serial read" so as to demonstrate the whole file working as a whole entity (for my presentation)
I am quite aware that there is a "random number generator" and "read from spreadsheet" that could help me accomplish this.
But i just cant figure out the whole logic.
(2,832 Views)
