Simulation Loop: Code could not be generated correctly for this VI
Running LabView Simulation 8.2 on Windows XP laptop.  I have a Simulation Loop that keeps generating the following error message:
"Simulation Loop: Code could not be generated correctly for this VI"
The only reference I can find in my searches is to using an RTX target, which does not apply.  When I click on Show Error it just highlights the Sim Loop
Any ideas on how to debug this?
(3,904 Views)
Perhaps you can start removing things until you don't get the error any more. How big is the code in the loop?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,903 Views)
Did you ever resolve this problem?  I am getting the same error and am not using RTX.
(3,797 Views)
Is there any solution to this annoying bug? I also get the same the error, as well as a lot strange dialogs, and can't find any useful solution.
(3,694 Views)
What do you have inside of the Sim Loop? Do you mind sharing your code?
Andy Chang
(3,679 Views)
