Simulated PCI-6259 missing Ctr0Out
Good Afternoon,
I am simulating a PCI-6259 as "Dev1," and am unable to locate & select the DAQmx terminal "Dev1/Ctr0Out."   According to the MAX pinout map this terminal exists, so my question is where did it go?   If I force with manual entry I recieve an error.   I've attach my VI for reference.   Any thoughts?
Labview 8.5.1
NI-DAQmx device driver 8.7.1f2
MAX 4.4.1f0
Sincerely,
Zach
(3,061 Views)
Hi super-neuron,
If you look at the pinout map for the PCI-6259 in Measurement and Automation Explorer (MAX), below the pinout diagram, it mentions that the default pin for Counter 0 Output is PFI12 (pin 2). This is the reason why you will not see Ctr0Out in your list of terminals in LabVIEW.
I hope this helps,
S_Hong
(3,010 Views)
Thank you S-Hong!
(3,004 Views)
