Simplifying Code
This snippet gave you the same colorful graph as mine?
Message 11 of 20
(2,724 Views)
Not a chance!  There is nothing in that example to change the waveform generated between each iteration or to slow it down to human speeds.  So, it looks fairly boring while running.
If you want something pretty to watch try this mod (backsaved to 2012)
"Should be" isn't "Is" -Jay
Message 12 of 20
(2,714 Views)
Yeah, I ended up using the Tone Generation with Noise VI.  It looks prettier then.  But if you want white to always be your newest, then you need to try this modification I just did.  It uses Rotate 1D Array and Replace Array Subset is set to always replace the first element.  It is a more 1-to-1 of what you have, but I think it uses more memory.
Message 13 of 20
(2,710 Views)
Im sad about it 😕 Mine is working but how can i scale the number of used shift registers?
Message 14 of 20
(2,707 Views)
Here is my project, i cant get it work 😕
Message 15 of 20
(2,704 Views)
If u look at my project I want to ask that dont u know how to change teh color or delete the frame of the clusters?
Message 16 of 20
(2,699 Views)
I got it work!
Message 17 of 20
(2,693 Views)
@gbvbalint wrote:
I got it work!
Great!
Post what you needed to change and a small write-up of what you learned along the way.  (trust me -You will come back to it often)
Message 18 of 20
(2,662 Views)
I used the snippet of crossrulz. The problem was that i took the code in a little individual loop first. Later i realized that, i just have to put it to the main loop, and woila it worked fine! I think your code would solve my problem too, but i didnt try it after the first worked. Thanks for your help!
Message 19 of 20
(2,658 Views)
My tweak to Tim's code just help visualize his method.  Glad to have helped!
Message 20 of 20
(2,656 Views)
