Simple string to array problem
Hello All,
I wrote a program that writes the time/date/ etc.. in this format. "%m/%d/%y %H:%M:%S"
However, to be able to write into spreadsheet, I have to transform it into an array..
However, the array seems to only display the %m/ part and not the rest.
What should I do to fix it?
Ben
Aquaphire
---USING LABVIEW 6.1---
(3,924 Views)
I was playing with something similar to this in one of my programs. All I did was wire the output of the "Format Date/Time String" to a "Build Array" function, and then I was free to wire that array to "Array to Spreadsheet String" or however you want to get it into the spreadsheet. Hope this helps.
Geoff
(3,918 Views)
Hey dennis,
Thanks for answer.
However, thats exactly what I did. The problem is that it will cut off half of the information...
instead of showing: 06/23/05 14:16:02
it shows: 06/
(using the build array fct)
Aquaphire
(3,915 Views)
You're going to have to post an example of the problem you're having. I've attached a VI with a build array and the text you mention, and the output array'sfirst elemetn has the entire string.
(3,911 Views)
here it is. I can't see your example since i only have labview 6.1...
thanks.
Aquaphire
(3,908 Views)
The build array is not cutting anything off. You didn't include ModifiedWriteStringToSpreadsheet and that's probably where the problem is. Use a format string of %s to tell the function to write a string to the file instead of a number. With a default format specified of %.3f, only the first part of your date/time is a valid number and the rest is truncated.
(3,900 Views)
Luv ya dennis. You're a god.
Many thanks 🙂
Aquaphire
(3,893 Views)
