Simple signal toggle switch
Hi all,
I have two sub-VIs which I want to switch between using a simple toggle switch. One generates a sine wave and one generates a cosine wave (both can have their frequency and amplitudes adjusted). I am using LabVIEW 6.1 and can only seem to find Boolean switches.
Is there an easy way to toggle between the outputs of these two simple signal generators?
Many thanks,
David Hogg
(3,063 Views)
Hi Hogster,
You should use your switch to control a case structure. This case structure will have a true and a false case. In the true case put sine subvi while in the false case put the cosine subvi.
Cheers
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
(3,058 Views)
Many thanks Doc-doc, I will try this 🙂
David
(3,048 Views)
