Simple question about Array subset
Well guys, I have an array with 1000 numbers and I want to split it in 10 arrays with 100 numbers each
My question is:
In array subset I can put the index and the length, in the first array subset I put index 0 and length 100, I think it will start at index 1, since 0 don't exist, right?
so in the next one I put the index 100 and it will start from index 101, or I have to put index 101 to start in 101??
because the length will always be 100.
Example:
1000/10 = 100
So I have to create 10 arrays with 100 number in each
Sincerely,
Eduardo
(3,400 Views)
Accepted by topic author EduU
LabVIEW arrays are 0 based, so the first element has index 0. Element 101 has index 100. So yes, you have to specify index 100 and length 100 to get elements 101..200.
(3,397 Views)
Thanks dan_u!
So it will be like this:
1º:  0-100
2º:100-100
3º: 200-100
4º: 300-100
5: 400-100
6º: 500-100
7º: 600-100
8º: 700-100
9º: 800-100
10º: 900-100
Right?
(3,394 Views)
If your list is index-length then yes.
(3,391 Views)
Yes, I thought on type it but I forgot!
Thanks dan_u!
(3,387 Views)
