Simple program not working
Hi
I have written what should be a simple program, however I am not getting an output voltage on the digital output line. Why? I checked for voltage using a multimeter.
I have attached the program
Greg
Message 1 of 9
(5,605 Views)
Hi Greg,
when I open your VI it shows a broken wire.
Simple solution: as long as you have a broken wire you cannot run your VI. Clear the error for that broken wire!
What kind of device do you use? There are open collector (or relais) type devices where you cannot simply use a DMM to measure a voltage…
Message 2 of 9
(5,586 Views)
Downgrade your code to LV 2013 or less and attach in the same thread.
Pankaj
Message 3 of 9
(5,573 Views)
Hi
Sorry about that, I have the connection mended.
The correct program is now attached. I am using a Mydaq.
Does the program look correct?
If it does, I will have to look at the circuit hardware (LED and Resistor)
Greg
Message 4 of 9
(5,568 Views)
Hi Pankaj,
it's just a boolean control and a DAQAssistent in a while loop, you don't need to see this… 🙂
Message 5 of 9
(5,567 Views)
Hi Pankaj
How do I downgrade the program?
Greg
Message 6 of 9
(5,564 Views)
Hi Greg,
are there any error messages? Have you enabled error display?
Why do you bang your hardware in a "fast as it can"-loop? Why don't you use some timing in your loop?
Message 7 of 9
(5,561 Views)
There are no error messages....
Greg
Message 8 of 9
(5,551 Views)
What is the digital line connected to?
Did you wire up the error output to an indicator?
Message 9 of 9
(5,531 Views)
