Simple problem but need help!
make a for loop that takes an array and iterates over each element adding “I” to the element then sends out the new array. ex) [3,10,20] input should output [3,11,22]
I think this should be simple but i have been stuck for a while please please can someone help be how to wire this out? example with sample wiring picture would be great!
(3,274 Views)
Have a for loop remove all odd numbers from “Loop In”
 Please if someone could please explain how to wire this. Please explain and sample labview wiring picture would be great! thank you!
(3,276 Views)
Hi AMG,
both questions can easily be solved after going through the free beginner courses offerd by NI here - or in the header of the LabVIEW board…
Btw. we will not solve your homework. Do the learning, start to code, attach your VI and tell us where you are stuck!
(3,261 Views)
Hope your statement itself contains the answer
Make a For loop with auto indexing the elements and Add the elements with (i), from the for loop output create an array of Added values.
(3,239 Views)
Always try something by your own and post the tried solutions to get the actual solution. so that it will make you understand better based on your own code.
(3,237 Views)
