Sample rates and accuracy shouldnt be an issue. I need to have the analog input connections update every few seconds, just so that the system operator can get an idea of the systems response when adjusting valves, flowrates, etc.
I would like to have the analog input values logged to a file say, once every hour. Additionally, the system will be running on a 4-10 minute cycle. I need to have a few (perhaps 5) cycles recorded each day. This recording could be in the ballpark of once every few seconds for 20-40 minutes and only needs to include 3 of the input connections.
I am using two LabJack U12 USB boards which as I believe means I can only have 2 executions through the USB port at the same time. (?)
The OS is windows XP
If it helps, Im operating a biological treatment system which needs only a cycling of two pumps, and on/off for a few valves. The system should take 4-8 weeks to reach a steady state of operation, so the sampling rate does not need to be fast.
I can put VI's together that would do all of these things, but I can't get them to work together.
Thanks, Rick
Message Edited by RickCSM on
07-08-2008 11:01 PM
