Simple OOXML reports
I've just discovered this library
Simple OOXML
http://simpleooxml.codeplex.com.
Did you ever used for reports?
Thanks.
(3,872 Views)
FYI, your link includes a period at the end, so it results in Error 400 when clicked.
It looks like this is just like the Report Gen Toolkit, but uses Open Office instead of needing a Microsoft Office license. So really this is only helpful if you already don't plan on using Microsoft in the first place and instead are okay with Open Office. I haven't used this, but it still uses ActiveX methods, so it should perform the same way Report Gen Toolkit does.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(3,831 Views)
No experience with that or other options (I don't do that much reporting), but I seem to remember seeing an OO extension to the RGT on the LAVA forums a few years back. I would search there.
___________________
Try to take over the world!
(3,799 Views)
