Simple Network Published Variable help
I am writing a program to be a "LabView wrapper" for iperf
I need to run iperf server and iperf client on two different machines.
Machine A: Launch iperf server and write ture to a shared variable
Machine B: Read shared variable and launch iperf client if machine A is running iperf server
I have never used a shared variable before, I have looked at the examples but as usual they work but are lacking and explanation as to why or how.
I have managed to get as far as creating a shard variable as a network published type Boolean Putting a shared variable on my block diagram I can select the server variable from my project just fine but the shared variable is read only?
How do I write to a shared variable?
=== Engineer Ambiguously ===
(3,155 Views)
Accepted by topic author RTSLVU
Right click and change the access mode to write
(3,146 Views)
I knew it was somthing simple I was overlooking
(3,142 Views)
