Simple NI-579X Streaming
Hi there, I want to run the example Streaming Xcvr (NI 5791) (FPGA).vi / Tx Streaming (Host).vi from the Simple NI-579X Streaming template (with NI 5791 & 7966a) on Windows 7 Ultimate SP1 and Labview 2017SP1 + FPGA + RT modules.
I have an oscilloscope connected to TX OUT pin on NI 5791 board and I can only read the carrier wave (300MHz), I cannot see the modulated IQ waveform generated in Host. I assume the FIFO underflows is the reason (as it can see on printscreen) but I don't know the reason of this behavior.
Any information is appreciated
Thanks in advance.
My enviroment is (attachment is included):
Target Class: PXIe-7966R
FPGA Device Information:
Family: Virtex-5
Type: xc5vsx95t
Speed Grade: -2
Package: ff1136
Resource:
Total Slices: 14720
Slice LUTs: 58880
Slice Registers: 58880
Block RAMs: 244
DSP48s: 640
Compiler Information:
Version: Xilinx 14.7
Xilinx Options in Build Specifications: Not supported
Host Computer/FPGA Communication:
Programmatic FPGA Interface Communication: Supported
Interactive Front Panel Communication: Supported
Number of Logical Interrupts: 32
DMA:
Number of DMA Channels: 16
Multi-Element Access on Target: Supported
Peer-to-Peer Streaming: Supported
Memory outside the FPGA:
DRAM:
Banks: 2
Bank Size: 256 MB
Data Width: 128 bits
Message 1 of 1
(1,356 Views)
