Simple Graph Question - Outlines
Hello wonderful people,
Can anyone help me achieve what you see in the pictures below?
I simply want to add the border around the whole graph area. The picture was created by a simple modification of the original in paint.
They were created using the Get Image Invoke node for an XY graph control.
Many Thanks
Nick
(3,887 Views)
You need to use the graph properties, here's an example:
The color constant does not appear when doing a code snipet.... I have attached the VI.
(3,844 Views)
Thanks, this is pretty close.
You will still notice that the top and left hand side is a different colour to the bottom and right...
Thanks for your help.
(3,833 Views)
It looks like the box used as a small 3D effect which create a shadow.  One possible solution is you can put a flat box over it.  You will have to resize the flat box if you change the graph size.
If anyone knows how to changed this with properties, let us know.
Here'an example.
(3,825 Views)
