Showing results forĀ
Search instead forĀ
Did you mean:Ā
Simple FFT graph problem
Hi to all,
The problem is: I have  a 100Hz sine in a text file (sampled at 800Hz), and when try to see the FFT of that signal, the dominant frenquency should be around 100Hz, but doesn't happen. I think that's because the "Convert to Dynamic Data" VI, but how can I solve this? The VI and the signal file goes in attachment.
Thanks in advance.
Ricardo.
(3,088 Views)
Before converting the array into the Dynamic Data type, convert it into a waveform type.  Feed the data into the Y element of the waveform cluster and enter the inverse of the sampling rate into the dt element of the waveform cluster.  Feed the waveform data into they Covert to Dynamic Data and change the properties of it to accept a single 1D waveform.  Your frequency info will then appear in the FFT.
Looking at your data, if this sine wave is at 100 Hz then it is not sampled at 800 Hz.  It is sampled at a higher rate.
Randall Pursley
(3,077 Views)
Thank you very much rpursley8. You helped me. My signal is sampled at 2,3KHz indeed. Thank you for your help.
(3,062 Views)
