Simple DAQ adcquisition questions
Hello Guys,
I am finishing my DAQ LabView module and i have some questions.
I am using waveforms to save the data. My module only has 8 inputs and my board has 16 outputs. I will use a switch but i want that this switch also changes the name of the data. Example:
In first screen appears the time and the value and the prompt "y". Am i able to change that to what i tant?
Second question: Can i delete the miliseconds etc... so annoying and not going to use. Probably DAQ during hours but only getting data like each 1 minute.
Third question (second image): There we have a 1 input schematich. Will be rough to have 8 like that to the computer? Will i lose my data? Will be better to create a For i=1 to 100000000000 and saving each 10 minutes?
4th question: Am i able to manage my panel through my Android / Ios device?
Appreciate the help.
(2,818 Views)
Post your code.  See the section "Attachments" at the bottom?  Push "Choose File", and then find the VI (not a PNG, but the actual VI) and select it.  If you have multiple VIs to attach, compress the folder that contains them all and attach the resulting .ZIP file.
(2,766 Views)
