Simple Angle Conversion
I cannot think this morning... what I need is super simple I feel like, but I can't figure out an easy way to implement it. Please halp.
Inputs: angles c and d:
current angle = c
desired angle = d
Output: angle z that is closest angle to c but is also in the set {d, d+-360, d+-720, ...}
examples:
c=0
d=270
z=-90
c=765
d=0
z=720
c=-361
d=-1
z=-361
c=0
d=3,602
z=2
Redhawk
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
Message 1 of 13
(4,445 Views)
Hi Andrew,
@FireFist-Redhawk wrote:
inputs: angles c and d:
current angle=c
desired angle = d
output: angle z that is closest angle
examples:
c=765
d=0
z=720
Please explain this example!
Why should z be 720° when c=765° (=720°+45°) and d=0°???
Message 2 of 13
(4,426 Views)
Hi GerdW,
I'm not sure I understand you're query. If my current angle shows 765, and I want to go to 0 (same place for me as +-360,+-720), then z is 720 because its the member of that set whose value is closest to my current angle, 765.
Redhawk
Message 3 of 13
(4,418 Views)
That description was initially a comment label in LV, I went back and cleaned it up to possibly get rid of the confusion, and added a couple more examples.
Redhawk
Message 4 of 13
(4,412 Views)
I think this does everything you need.
The idea here is to find the differences and keep that difference in a shift register.  Add (or subtract) 360 until the absolute value of the difference is greater.  The previous value is therefore the closest value.
Message 5 of 13
(4,405 Views)
Can you explain it graphically instead?
Message 6 of 13
(4,402 Views)
Hi Andrew,
please explain this one:
c=0
d=3,602
z=2
Edit:
I think I get this one - decimal separator confusion. I'm used to commas instead of points…
Message 7 of 13
(4,394 Views)
Accepted by topic author FireFist-Redhawk
Let's say
e=(c-d)
and z'=(z-d)
then, you are looking for a z' in {..., -720, 360, 0, 360, 720,...} for which the difference to e is minimal.
Dividing e by 360 using the quotient & remainder VI gives a quotient which, multiplied with 360 again, is the next lower multible of 360 to e. If the remainder is >180, add 360 to get the nearest value. This is z'. Add d to get z.
In LabVIEW:
EDIT:
c=0
d=3,602
z=2
z must be in {..., d-360, d, d+360,...}, so it must be d=3,602 to be next to c....
Message 8 of 13
(4,377 Views)
That's very dangerous code because it will run forever if any of the inputs is NaN. 😮 Maybe you want to reverse some logic so it stops on FALSE instead.
(I am pretty sure there is a loop-free solution ;))
Message 9 of 13
(4,369 Views)
I think we all have the idea at this point but it took me a few mins to make, so may as well post.
Redhawk
Message 10 of 13
(4,319 Views)
