Simon game
Hi I'm creating the simon game code in labview but I have 3 problems that I haven't solved yet:
1. When two colors will come repeated in the sequence the lights not blink. For example: Red,yellow, blue, blue..., blue color just blink once. Somebody know how to correct this?.
2. And the second is how to create a boton to start and stop the game when the user wants?
Thanks for your suggestions
I attached my code.
(1,631 Views)
Go back to the tutorials and look at the shipping examples and design templates. (maybe even search the forum).
  • All you need is a simple state machine.
  • One outer while loop, one case structure, and a few shift registers to carry state data.
  • You don't need any local variables.
  • You don't need any sequence structures.
  • You don't need any event structure (an event structure hidden deep inside sequence frames and even a FOR loop is a really bad idea!)
  • Your arrays should be integers.
  • Done right, the final code should easily fit on a postcard.
(1,593 Views)
