Silver push button - Graphics issue
Hello
I have a graphical issue with Silver Push Buttons.
In my deployed VI it's fairly consistent. The issue occurs in the same button repeatedly, but can occur in other buttons, but this is fixed after a restart.
Issue:
Push Button turns blank after being pushed.
Button is configured as "Switch when released" and is a Silver Control.
1# Before use
Before pressBefore press
2# After use
After pressAfter press
I have seen this issue also occur on my dev pc, but inconsistently. Only consistent when deployed.
Any idea what's causing it, and how to fix it?
(1,555 Views)
It is easy to reproduce by just coloring the bright yellow triangle transparent. (B)
Could it be you did that by accident?
Hard to tell what else could be going on. Are the graphics drivers updated?
(1,543 Views)
No transparency is being applied to the buttons.
Did some more testing. It's entirely inconsistent, both between restarts and re-runs of the program.
It's definitely a graphics issue, once i scroll/pan the button appears in the expected state again. Clicking it changes the state and it goes blank again.
I'll check the drivers next.
(1,476 Views)
