SignalExpress to Labview implementation
I have few Oven system monitoring with signal express limited edition (3 or 4 pc monitoring oven temperature with signal express). Hardware are NI 9211. Due to data logging limitation in signal express LE, so i need to develop labview project at 1 centralize pc and how can i get all temperature real time value from signal express systems?
Attached is one my existing signal express project.. it is monitoring fine for oven temperature but i need to get data logging generate from labview project.
Can someone pls kindly advise?
Thanks and Regards,
Brian
(3,040 Views)
When you implement it in LabVIEW you don't really need the signal express. Do the data acquisition from NI 9211 directly in LabVIEW with proper scaling and log the data using LabVIEW.
(3,015 Views)
Hi P@Anand,
Thanks for your response. There are some limitation with my project. Those 9211 modules are not direct connect with my labview full development pc.
They are like one NI9211 monitor 4 channels temperature with Signal express LE version in many standalone pc.
So i have to centralize monitoring in 1 pc. Get all the standalone pc signals from many pc / system and develop a labview program to monitor temperatures and get all real time data logging..
(2,988 Views)
