Signal processing
hi,
I'm Ayushi
i want to detect the peak between these two points using array as shown in the below picture .
Message 1 of 10
(4,585 Views)
hi and welcome to the forum!
please skim through this post to get you started
https://forums.ni.com/t5/Community-Documents/Unofficial-Forum-Rules-and-Guidelines/ta-p/3536495
and check your post again .. your image 😞 ... is ... (almost) ... empty
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 2 of 10
(4,579 Views)
HI,
I WANT TO DETECT THE PEAK BETWEEN THESE TWO POINTS AS SHOWN IN THE FILE
Message 3 of 10
(4,570 Views)
Accepted by topic author ayushi141
Hi ayushi,
find the valleys between your points, then find the peak between the valleys…
Message 4 of 10
(4,561 Views)
Hi.
Isn't your problem would be solve by using the 'peak detection vi' twice ? (found in maths\signal processing\Signal operation)
Once for finding the valleys, then a second time to find the peak between those valleys.
Message 5 of 10
(4,554 Views)
thanks,
i found the valleys , but i'm not able to find the peaks between these valleys..
Message 6 of 10
(4,499 Views)
Hi ayushi,
Why aren't you able to find them?
What have you tried?
How does your VI look like? (Attach it!)
Are you really looking for the peaks just in the subset of your waveform between each pair of valleys?
And why don't you find both valleys in the 3rd period of your signal?
Message 7 of 10
(4,491 Views)
i want to detect the peak  between each valley .
please find  the  attachment of my vi.
Message 8 of 10
(4,479 Views)
Hi ayushi,
right now you try to find all those peaks/valleys/inner peaks globally on the whole waveform!
As said before: try to find those inner peaks just between the valleys found previously!
So you need to implement 3 steps:
1. Find "upper" peaks.
2. Between each pair of peaks from step 1 you need to find the valleys: work with just a subset of the whole waveform from step 1.
3. Between the two valleys from step 2 you again take a subset of the waveform and now try to find the peak on just that subset!
Message 9 of 10
(4,474 Views)
Dear All,
I want to use LabVIEW Advanced signal processing toolkit(Discrete wavelet Analysis VI) for feature extraction purpose,I have read the signal samples using the read from spreadsheet vi and set to the vi for wavelet analysis purpose,my intention is to find the details and approximate coefficients like Matlab,how could i make that one in LabVIEW(extracting the detail coefficients and approximate coefficients and then plotting the detail coefficients vs the sample or time)
thank you for your help.
Message 10 of 10
(4,407 Views)
